Product: | MicroStation | ||
Version: | CONNECT | ||
Environment: | N\A | ||
Area: | Graphics Display | ||
Subarea: | Display Rules |
I have created a hatch display rule for the "cut" display style. It works fine in the model, but will not display when attached to a sheet file. I am using the saved view method and attaching the saved view as a reference file to the sheet.
Introduced in MicroStation CONNECT Edition (Update 13) onwards, we have introduced a variable:
MS_PATTERNORIENTATION_ROTATEWITHVIEW
This supports the Display Rule, Hatch, in references for non top sections.
If you set this variable to 0 you should be able to see the Hatch in the sheet
eg.
MS_PATTERNORIENTATION_ROTATEWITHVIEW = 0
Pattern orientation mode. 0 indicates pattern orientation of reference is fixed to a view, 1 indicates pattern orientation rotates with reference.
Display Rule Hatch only visible in top view?
Original Author: | Andrew Bell |
