| Version: | 08.11.07.443 | ||
| Area: | Drawing Aids | ||
| Subarea: | Snaps |
Construct tangent and other commands. Where to find the tools to create arcs, circles tangent to elements and where to find the tool to create elements perpendicular to other elements.
Key ins are available.
construct tangent circle 3 etc.
The commands are not in the default interface because by using the various Snap
tools the same results can be obtained. Often with more flexibility.
The older commands are still available as key ins.
They start with the word: Construct
Examples:
Construct Perpendicular To
Construct Perpendicular From
Construct Tangent To
Construct Tangent From
Construct Tangent Circle 1
Construct Tangent Circle 3
Construct Tangent Arc 1
Construct Tangent Arc 3
Construct Tangent Between
Via the keyin:
dialog palette 40line
a toolbox with these older commands will pop up.
| Original Author: | Henk Ligtvoet |
