| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 24 July 2012 |
| Date modified | 24 July 2012 |
A simple trick when one wants to recalculate a lot of phases, is to CTRL+Click on the phase icon in front of the phase name, and all phases that follow from this phase will be set to to be calculated:
In the example above, phase 4 and phase 5 are not modified, since these phases do not originate from phase 3, but from phase 2.
This trick also works if you want to disable such a phase tree branch (a phase with all its child-phases):
This feature is introduced in PLAXIS 3D2012
