| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 02 March 2015 |
| Date modified | 02 March 2015 |
With the Trim/extend function from the right mouse button menu it is possible to trim or extend lines. To use this feature:
Two examples are shown below, and in the animation below:
Note that using this option through the command line, the following command should be used: snaplinear.
It takes two arguments: first the endpoint of the line to be trimmed, and secondly the line it should trim/extend to, for example:
Also see the command reference from the Help menu for further information.
