| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Original Author | G. Tjie-Liong |
| Date created | 15 November 2011 |
The use of a spring constant for the design and analysis of raft and pile-raft foundations has many limitations, related to the proper estimation of the spring constant magnitude and the soil structure interaction. Spring constants have been used for example in the design of a Mass Rapid Transit railway station in an oversea project.
