| Version | PLAXIS 2D PLAXIS 3D |
| Original Author | T. Meier |
| Date created | 05 March 2012 |
A general description of the two constitutive models applied in the thesis ”Application of Hypoplastic and Viscohypoplastic Constitutive Models for Geotechnical Problems” is given here. The main attention is on the procedure for the determination of the material parameters from laboratory tests and on post test numerical simulations.
