| Version(s): | 10.16.03.11 | ||
| Area: | Levels | ||
| Subarea: | Level Display |
Element Levels display as (none)
Element levels display as (none) even though they have an assigned Name
The Level display format was set to “D”. Level Description was empty (not set)
MS_LEVEL_DISPLAY_FORMAT = D
D: Use level description
Resetting the Level display configuration variable value, fixed the issue.
How can you see level name and number
