| Version: | V8, 2004, XM, V8i, CONNECT | ||
| Area: | Text | ||
| Subarea: | Text Styles |
How do I create a Text Style in MicroStation and where can I locate these tools?
The below steps are shown in MicroStation CONNECT Edition, however they can be applied to previous versions.
First, launch the Text Styles dialog from Drawing workflow>Annotate tab>Text Ribbon Group
You should then see the Text Styles dialog box:
Select the "New" icon, which looks like a blank piece of paper, or select "New" from within the Style pull-down menu.
Highlight the "Untitled" text and enter a new Text Style name.
Set up the desired settings for the text style which would include:
After these settings have been finalized, click on the "Save" icon or select "Save" from the Style pull-down menu.
Further detail can be found in the online help documentation:
Text Styles - online help
How to Create a Dimension Style - wiki
Text Styles And Dimension Styles and How They Interact - forum post
1 Place Text with Different Text Styles - Youtube
