| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Original Author | P.G. Bonnier, M. H. Kappert, R. B. J. Brinkgreve |
| Date created | 20 May 2011 |
The paper shows a derivation of hysteretic damping from the small-strain stiffness formulation in the HSsmall model. In this way, the modulus reduction curve can be linked with a damping ratio curve for dynamic applications. The damping hysteretic characteristics are demonstrated in a simple example.
