| Version | PLAXIS 2D PLAXIS 3D |
| Original Author | E. Hoek, C. Carranza-Torres, B. Corkum |
| Date created | 20 May 2011 |
The paper describes the 2002 Hoek-Brown failure criterion formulation an model parameters, as well as the match to the Mohr-Coulomb failure criterion.
