| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Pen Table | |
Problem Description
I need to convert my Color Maps and Weight Maps from my Printer Driver Configuration file into my MicroStation Pen Table
Steps to Resolve
- Open your Print Dialog box and attach Pen Table where you want to import the Maps into
- Select Resymbolization->Edit Pen Table
- Click on Map Pen Colors...
- Click on Edit->Import from Printer Driver Configuration... Select your .pltcfg file and OK
- To import your Weight Maps repeat steps 2-5 this time for step 2 select Map Pen Weights...
See also
Other language sources
Deutsch
