| Version(s): | 10.02.00.39 | ||
| Area: | Text | ||
| Subarea: | Favorites |
1. Start the Place Text tool
2. Select the Insert Field icon from within Text Editor dialog
3. Set Field Type = Element Properties and click OK button
4. Identify the Element/Geometry which has properties
5. Choose the required property
6. To add more properties, repeat Step 3, 4, 5
7. Now select all the text inside the Text Editor, right click and select Save Text Favorite
8. Enter the text favorite name
9. To save the text favorite as group, enter {Group Name}:{Text Favorite Name}
How to place and update fields in MicroStation?
Text Fields - Auto Updating Annotations
How to place a Text Favorite and use selected element properties
How to change the Unit Label for a Text Field
| Original Author: | Leonard Jones |
