| Version: | V8i, CONNECT | ||
| Area: | Text | ||
| Subarea: | Word Processor |
Text Fields in your design file, connected with element, model or file properties, are not automatically updating when this information changes.
The following YouTube video is quite helpful showing how you can place a Text Field using one or more of the various properties but also shows what is required to ensure this is automatically updating.
Use the key-in: FIELD UPDATE ALL
Text Fields - Auto Updating Annotations
How to change the Unit Label for a Text Field
