| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Original Author | S. Brinkman |
| Date created | 19 October 2011 |
Many coastal zones around the world are characterized by the presence of soft soil sediments, which are prone to erosion. The critical areas are therefore protected by engineering structures, like revetments and breakwaters. The structures and their foundations should be able to resist earthquake loads and deformations should remain within acceptable limits.
