| Version | PLAXIS 2D PLAXIS 3D |
| Original Author | A. Nasekhain, H. F. Schweiger |
| Date created | 18 October 2011 |
The report describes the validation of the Hoek-Brown model as a standard model in the PLAXIS calculation kernel. Since the user-interface was not available at that time, the authors modified the PLAXIS input files to use the Hoek-Brown model with corresponding parameters in the calculation kernel. Conclusions are included.
