| Version: | CONNECT | ||
| Area: | Printing | ||
| Subarea: | Driver/PDF |
It is taking relatively a longer time to print to PDF in CONNECT Edition.
You can disable some of these options in the PDF pltcfg.
From the (PDF) Print dialog box, go to File > Edit Printer Driver Configuration and edit these settings:
Enable bookmarks=OFF
Enable Links=OFF
Enable Searchable Text=OFF
Enable Optional Content=OFF
Enable Measuring=OFF
Enable geo-referencing=OFF
Rasterized Quality Factor=50
The following variables can be used to improve the speed of the rasterized print. They can be defined under file – Settings – Configuration – Configuration Variables.
MS_PLT_RASTERIZED_MAX_TILE_WIDTH
and
MS_PLT_RASTERIZED_MAX_TILE_HEIGHT
Note: Tile Width / Height used for rasterized printing. Default width / height size is 2048 and max is 8192.
Set the values 4096 or 8192 for the above variables.
After editing, save the file and reload to use.
| Original Author: | Judy Wong |
