| Version(s): | CONNECT | ||
| Area: | UI Customization | ||
| Subarea: | Function Keys |
It can be handy to customize the functions keys F1 to F12 to open the tools or perform actions you use the most. This speeds up your productivity considerably and is recommended for fast paced environments that have frequent deadlines.
As an example we will program the F7 function key to open the Measure Distance Perpendicular tool.
Go to File > Settings > User > Function Keys and change the Function Key to F7. Copy/paste the desired command into the "Action" box as shown:
Press save and thereafter be sure to Save Settings (CTRL+f).
| Original Author: | Anders OMahony |
