| Version: | V8i, CONNECT | ||
| Area: | Interchange | ||
| Subarea: | SHP |
When trying to import, open or reference a GIS file (SHP, MIF/MID, or TAB) the following message appears:
"[...FilePath...shp] is not in a recognized file format"
When attempting to open:
When attempting to import or reference:
Reason 1: Using a version older than MicroStation V8i SELECTseries 1 (08.11.09.171)
The ability to open, import and reference GIS files (SHP, MIF/MID, or TAB) was introduced in MicroStation V8i SELECTseries 1 (08.11.07.171). Older versions do not include this feature.
Reason 2: Supporting files are missing
Shapefile Format: SHP
Require at least three files in the same directory, with the same name and with the following extensions:
File Extension
Description
.shp
Shape Format: Describe the feature geometry such as points, polylines, and polygons
.shx
Shape Index Format: A positional index of the feature geometry to allow seeking forwards and backwards quickly
.dbf
Attribute Format: Columnar attributes for each shape, in dBase III format
In addition to the three mandatory files listed above, you can include the following optional files:
File Extension
Description
.prj
Project Format; contains the coordinate system and projection information, a plain text file describing the projection using well-known text format
.sbn and .sbx
A spatial index of the features
.fbn and .fbx
A spatial index of the features for shapefiles that are read-only
.ain and .aih
An attribute index of the active fields in a table or a theme's attribute table
.ixs
A geocoding index for read-write shapefiles
.mxs
A geocoding index for read-write shapefiles (ODB format)
.atx
An attribute index for the .dbf file in the form of shapefile.columnname.atx (ArcGIS 8 and later)
.shp.xml
Metadata in XML format
.cpg
Used to specify the code page (only for .dbf) for identifying the character encoding that will be used
MapInfo Format: MIF/MID
Require at least two files in the same directory, with the same name and following extensions:
- MIF (Stores geometry)
- MID (Stores database attributes for the geometric data)
MapInfo Format: TAB
Require a number of files to be present in the same folder. These files make up a standard MapInfo project.
MicroStation Wiki - GIS Files: Open, Import or Reference
MicroStation Wiki - GIS Files: Elevation Data
MicroStation Wiki - GIS Files: Elevation data not applied after import
MicroStation Help - Using GIS Files
| Original Author: | Craig Calvin |
