| Application | PLAXIS 3D |
| Version | 3DFoundation |
| Original Author | F. Tschuchnigg, H. F. Schweiger |
| Date created | 14 November 2011 |
The ground anchor in 3DFoundation consists of two different parts. The first part represents the free anchor length and the second part the grout body. The free length is modelled as a node-to-node anchor, which represents the connection between the grout body and e.g. a diaphragm wall, and the grout body consists of embedded beam elements, which are line elements with a special interface to model the grout-soil interaction.
