| Version: | V8i, CONNECT | ||
| Area: | Interchange | ||
| Subarea: | SHP |
Elevation (Z value) data is not applied after importing a GIS file (SHP, MIF/MID, or TAB) and defining the configuration variable MS_ELEVPROP_AS_Z.
Reason 1: GIS files are imported with the elevation data available at the time of importing.
Elements are imported with the elevation (Z value) applied if the configuration variable MS_ELEVPROP_AS_Z is set before to importing the GIS file.
Steps:
Reason 2: Configuration variable definition is case-sensitive
Make sure value defined for the configuration variable MS_ELEVPROP_AS_Z matches the capitalization of the value used to define the attribute in the GIS file.
MicroStation Wiki - GIS Files: Open, Import and Reference
MicroStation Wiki - GIS Files: Unable to Open, Import or Reference
MicroStation Wiki - GIS Files: Elevation Data
MicroStation Help - Using GIS Files
| Original Author: | Craig Calvin |
