| Area: | Project Navigation | ||
| Subarea: | DGN Links |
How can I delete multiple Links from multiple Elements?
Links are added to Elements to convey additional information about the Element, such as a Link to a website, Image or document. Given this ask yourself do you really want to remove the Links, instead it maybe you just want to turn their display off, this can be done via a View Attribute switch.
Repeat above as required
How to attach several links from file to elements in MicroStation
| Original Author: | Carl Myhill |
