| Product(s): | MicroStation, MicroStation PowerDraft, Bentley View | ||
| Version(s): | CONNECT | ||
| Environment: | Windows 10 | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
Using V8i application versions, I was able to use the keyboard shortcuts to access tools and process various commands.
For example, A1: opens Text Editor, Q2: place line, etc.
How can I enable the same keyboard shortcuts for use in CONNECT Edition products?
CONNECT Edition - Using Position Mapping to get to tools really quickly
| Original Author: | Bentley Technical Support |
