| Version: | V8i, CONNECT | ||
| Area: | Reference | ||
| Subarea: | N\A |
How to attach references and have their Boundaries display permanently
This can be done by setting MS_REF_DEFAULTSETTINGS to displayBoundary=1.
This setting will force the boundary display of references even when Hilite Mode is NOT set to "Boundaries" or "Both" in the reference dialog box and/or the "Boundary Display" setting in View attributes is turned Off.
**Note - This setting was added to the 2004 Edition of MicroStation.
