| Environment: | Windows | ||
| Area: | Solids | ||
| Subarea: | Legacy Solids |
I wish to offset the top edge of the left-hand face downwards to form the base of the handrail that sits on the top of the existing solid, which is the side of an escalator..
- Keyin “dialog toolbox legacysolid”
- Use “Draw on Solids” tool from toolbox.
- Select the Draw on Solid tool.
- Select the Offset Edges icon.
- Select Method >Edges.
- Type in a value for the offset Distance.
- Select the target solid.
- Select a face or an edge. The edge loop becomes highlighted, and AccuDraw is oriented perpendicular to the selected edge (or nearest edge to selection point on a face).
- Move AccuDraw slightly to select the offset direction (inside or outside).
- To select additional edges, use “Ctrl” key to add and continue to the final edge of the solid.
| Original Author: | Judy Wong |
