| Version(s): | 08.11.09.459 | ||
| Area: | Text | ||
| Subarea: | Font | ||
| Original Author: | Judy Wong, Bentley Technical Support Group | ||
In the Word Processor Text Editor dialog box, using the "Insert Symbol" to insert "Diameter" showed an "asterisk" {*} instead. Font used is Engineering (Font 3)
Run "ustation.exe - RestoreDefaults"
