| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 30 May 2011 |
| Date modified | 30 May 2011 |
Where can I find a reference for the Command Line?
In the PLAXIS 2D and 3D Input, Output and SoilTest programs, you can find the Commands Reference in the Help menu. This will open the full Commands and Objects reference for the Input program, the Output program and the SoilTest program.
