| Version(s): | V8i and CONNECT Edition | ||
| Area: | Properties | ||
| Subarea: | Details |
User want to know if there is a way to change the element properties from New to Not-New.
With the Element Information tool this is not possible.
With the Element Information tool this is indeed not possible. Here you can only change whether an element is modified or not modified
Try using the 'old' Analyze Element tool.
You can start this tool using the following key-in: ANALYZE ELEMENT
This will open the Analyze Element dialog, as shown below
Select the elements with the Select tool, start Analyze Elements tool and change per element
Or you can use the key-in CLEAR NEWBITS
Start the key-in CLEAR NEWBITS and select/accept the elements you want to change
| Original Author: | Rene vandenBrink |
