| Version(s): | V8i, CONNECT | ||
| Area: | Configuration | ||
| Subarea: | General | ||
| Original Author: | Conor King, Bentley Technical Support Group | ||
How can a document be opened using a Key-in combined with a variable
A custom variable (e.g. TEST_DOC) has been created and a folder path assigned to it. Using the Key-in window, a document (like a pdf) in the folder assigned to the variable can be opened from within MicroStation by combining the variable in a Key-in
How to Expand Key-ins that contain configuration variables
