| Version: | CONNECT | ||
| Area: | Configuration | ||
| Subarea: | General |
This article describes how to start MicroStation with administrator privileges while logged-in as a "normal" user.
Pressing the ESC key on the keyboard should be simulated on a mouse button. This can be desired to cancel a command, not to select anything in the editor and also to get to position "Start" ("Home").
This can be achieved by placing the key-in command CHOOSE NONE on the desired mouse button.
