| Version: | V8i, CONNECT | ||
| Area: | Reference | ||
| Subarea: | N\A |
How to turn on the Save Relative Reference option and make it so it cannot be toggled off.
MS_ALWAYSRELATIVEREFPATH was added to 08.09.01.73.
When the configuration variable is set (to anything), then MicroStation always turns on the Save Relative Path toggle.
Before setting this variable
After setting this variable
Adding Configuration Variables
