How do I import a geometry in PLAXIS 3D?
Application PLAXIS 3D
Version PLAXIS 3D
Date created 30 June 2016
Date modified 11 November 2025
PLAXIS 3D allows importing points, lines/polycurves, surfaces and volumes, next to point cloud import. You can also import surface as the top and bottom soil surfaces of your borehole, in the Modify Soil Layers configuration window in the Surfaces tab. When importing a geometry file, a list of possible file extensions is shown.
Supported import formats
With the internal changes for the geometric data model for PLAXIS 3D 2016, the Input program will no longer support the import of triangulated geometry. This includes *.3ds, *.dwg and triangulated *.dxf files. For supported types of older PLAXIS versions, see the attached document.
Downloads
See also
