| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 09 November 2012 |
| Date modified | 09 November 2012 |
This document describes an example that has been used to verify the bearing capacity of a strip footing according to Davis & Booker (1973) in PLAXIS.
Used version:
