| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 06 November 2012 |
| Date modified | 06 November 2012 |
This document describes an example that has been used to verify the elasto-plastic deformation capabilities according to the linear-elastic perfectly-plastic Mohr-Coulomb model of PLAXIS. The problem involves axial loading under biaxial test conditions.
Used version:
