| | Product: | MicroStation | |
| | Version: | v8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Settings | |
| | Subarea: | N\A | |
Changing display priority is not affecting the display of elements.
Unable to get an element to display on top of another element.
Possible Reasons:
-File is 3D. Display Priority is not supported in 3D files. The View Z buffer controls display priority in a 3D file. In other words, what is closer to the view will be displayed on top.
Solution: Physically move the desired elements to change the position in the view plane.
-The elements have different level priority (If they are on different levels).
Solution: Modify the Bylevel Priority value of the desired elements to change display order.
-The elements have different reference Priority (If the elements are in different attachments).
Solution: Modify the Reference Priority value of the desired attachments to change display order.
How to Order Reference Attachments
Changing Element Display Order
Other language sources
Deutsch
| | Original Author: | Bentley Technical Support Group | |
