| Product: | MicroStation | |
| Version: | CONNECT Edition | |
| Feature: | Annotation |
| The Situation |
| Do you repeatedly find yourself annotating the same types of elements in the same manner? |
| Solution |
Save time using text favorites to alleviate the repetitive task of annotating similar elements. Text favorites are pieces of text that have been saved to a “favorites” list, allowing them to easily be reused without having to repeatedly type them in. Create and edit text favorites by means of property driven text fields to speed the placement of annotations in your designs. |
| Links |
| • YouTube • MicroStation Wiki • MicroStation Help |
To create a text favorite:
