| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 08 January 2013 |
| Date modified | 08 January 2013 |
This document describes an example that has been used to verify the groundwater flow capabilities of PLAXIS. The problem involves the unconfined flow through a sand layer and the resulting phreatic surface and total discharge.
Used version:
