Iterative settings: desired minimum and maximum
Application PLAXIS 2D
PLAXIS 3D
Version PLAXIS 2D
PLAXIS 3D
Date created 18 July 2011
Date modified 18 July 2011
The iterative parameters Desired min number of iterations and Desired max number of iterations are primarily meant to determine when the calculation should take larger steps or smaller steps. If the calculation can solve a load step (hence converge) in fewer iterations than the Desired min number of iterations, it starts using a load step that is twice as big. If, however, the calculation needs more iterations than the Desired max number of iterations to converge, the calculation will decide to choose a calculation step only half the size.
For a Plastic analysis or Safety analysis, there is no influence on the results when changing the Desired min or Desired max number of iterations. As long as the calculation converges every step, it is unimportant if the calculation uses a lot of small steps with few iterations or a limited number of larger steps with more iterations per step.
For a Dynamics calculation, the step size is constant, determined by the time interval and the number of additional steps and dynamic substeps, and so Desired min and Desired max number of iterations are not even used.
For a consolidation analysis, however, there is a small influence. As mentioned, the choice for taking larger steps or smaller steps is based on the convergence of the calculation. In a consolidation analysis during a load step (hence during a time step), water flows out of the soil, and generally, the flow is slightly higher at the beginning of the step than at the end of the step. However, in one time step, the calculation will calculate with a constant flow, and typically that is the flow at the end of the time step. This means that on average, the flow rate during a time step is slightly underestimated, leading to a slightly higher consolidation time. If the calculation takes larger steps, this effect is bigger than when the calculation takes smaller steps.
In practice, when a consolidation analysis takes several hundred steps, the influence on the consolidation time will be very small. However, for very specific cases where consolidation analysis only takes a few steps, for instance when modelling laboratory tests on highly permeable soils, there may be an influence of several percent. In that case, lowering the Desired minimum and Desired maximum in order to force the calculation to use smaller steps will improve the results.
A more common reason to change the Desired min and Desired max number of iterations in a consolidation analysis is the calculation time. In a consolidation analysis, the stiffness matrix depends on the time step, and so the time step must be known before composing the stiffness matrix. In case the calculation decides the step size can be scaled up or should be scaled down, the time step changes, and a new stiffness matrix must be composed. Occasionally, it happens that every other calculation step, the calculation decides to scale up, and then the next step scales down again. This means that for almost any calculation step, a new stiffness matrix has to be made, which is very time-consuming. In this case, slightly increasing the Desired minimum and Desired maximum can cause the calculation to change step size less frequently, which may give a significant improvement to the calculation speed.
In general, when decreasing the Desired Min number of iterations will cause less scaling up, and increasing the Desired Max number of iterations will reduce the number of downscales.
Manually controlling load stepping
A special option to control the load advancement scaling (size of the step) exists for setting these desired minimum and maximum values to specific values. When the Desired min number of iterations is set to 2 and the Desired max number of iterations is set to the maximum iterations, there will be no scaling up or down, and you will see a constant load step for each step.
Note that with arc-length control switched on, the actual load step may be smaller. For consolidation analyses, the arc-length control is switched off always, but for plastic calculations with arc-length control switched on, the load steps may differ in size a bit.
See also
