| Product: | MicroStation | |
| Version: | CONNECT Edition | |
| Feature: | User Interface |
| The Situation |
Would you like to access many of the most commonly used tools without having to switch workflows or ribbon tabs? |
| Solution |
Access many of the most common tools from the Ribbon Group Popups. The Ribbon Group “Popups” is a small, easily accessible, “popup” tool box that appears at the at the cursor pointer by pressing the <Spacebar> on the keyboard when the focus (input focus or keyboard focus) is Home. |
| Links |
| • YouTube • MicroStation Blog • MicroStation Help |
Accessing the Ribbon Group “Popups”:
Verify that the input focus is set to Home.
Press the <spacebar> on the keyboard.
Select the desired tool or group.
Note: An easy way to set the input focus to Home is by enabling the User Preference ESC exits command.
