| Product: | MicroStation | |
| Version: | CONNECT Edition | |
| Feature: | Precision Drawing |
| The Situation |
Have you ever opened a design file, selected a command, only to find the snap mode not set to your desired method of use? |
| Solution |
Set the snap mode for all files from User Preferences. The active snap mode is, by default, stored separately in each of the individual design files (DGN’s) that you work in. By setting a User Preference, MicroStation will allow the active snap mode to be read from User Preferences rather than the active file. |
| Links |
| • YouTube |
To set the snap mode to be read from User Preferences, do the following:
The snap will now remain as it was just set for every subsequent file that is opened.
