| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 14 November 2012 |
| Date modified | 14 November 2012 |
This document describes an example that has been used to verify the behaviour of plates in PLAXIS. The problem involves a concentrated load and a uniformly distributed load on a plate.
Figure 1 Loading scheme for testing plates (2D)
Used version:
