| Product: | MicroStation | |
| Version: | CONNECT Edition | |
| Feature: | User Interface |
| The Situation |
| Do you find yourself frequently referring to the command prompt to see what information MicroStation is looking for? |
| Solution |
Be more productive by displaying the MicroStation prompt at the cursor pointer. When working with the various tools and features found in MicroStation, it is very common to frequently refer to the command prompt, located in the lower left corner of the user interface. And while observing the prompt in the lower-left corner has long been the standard in MicroStation, a new option is available. You can display the command prompt at the cursor pointer by simply setting the value of the configuration variable MS_CURSORPROMPT = 1. This then displays a Cursor Prompt window that follows the mouse. |
| Links |
| • YouTube • MicroStation Blog • MicroStation Help |
When working with the various tools and features found in MicroStation, it is very common to frequently refer to the command prompt, located in the lower left corner of the user interface. This prompt helps identify what is needed next and is a part of the three-step rule for working with commands in MicroStation.
Three-Step Rule:
A pinned ribbon group will display the pin icon. The pinned group is now displayed, regardless of the active ribbon tab.
And while observing the prompt in the lower-left corner of the application window has long been the standard in MicroStation, a new option is available. You can display the command prompt at the cursor pointer by simply setting the value of a configuration variable.
This is accomplished by setting the configuration variable MS_CURSORPROMPT equal to 1 (the default value of this variable is undefined):
MS_CURSORPROMPT = 1
Set the MS_CURSORPROMPT configuration variable:
(Illustration 1)
(Illustration 2)
(Illustration 3)
(Illustration 4)
Note: System Administrators and CADD Managers can set this for multiple users by adding this variable to their overall configuration (such as a corporate or workgroup configuration file), affecting all users that access that configuration file.
