| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 16 December 2016 |
| Date modified | 28 April 2025 |
| Keywords | PLAXIS, commands, examine, log, reuse |
At times, you may need to work on the same geometry for different purposes in different projects, and it is possible to use the "Export geometry" option in the File menu in order to export the current geometry to a format such as DXF, STEP/STP and BRep.
Apart from the available command, there is a way to reuse the geometry through the functionality called "Examine commands" in the Expert menu.
How to recreate geometry using commands
Notes
