| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 09 January 2013 |
| Date modified | 09 January 2013 |
This document describes an example that has been used to verify the groundwater flow capabilities of PLAXIS. The problem involves the confined flow under an impermeable dam around an impermeable wall.
Used version:
