Product: | MicroStation | ||
Version: | V8i, CONNECT | ||
Environment: | N\A | ||
Area: | DWG | ||
Subarea: | General |
Prefix \ not working for DWG key-ins.
Prefix \ not working for DWG key-ins while in DGN files.
acad.pgp key-ins are not recognized when using the prefix \
The DWG command Prefix only works while in DWG files by default.
To use the command prefix in a DGN file, add the MDL application dwgsettings.ma to the MS_DGNAPPS configuration variable.
For information on loading MDL applications automatically, refer to:
Loading MDL Applications Automatically
Original Author: | Bentley Technical Support Group |
