| Version(s): | CONNECT | ||
| Area: | Drawing Aids | ||
| Subarea: | AccuDraw |
How to locate where my modified Accudraw shortcut keys are stored
Accudraw Shortcut key-Ins are defined as Keyboard Shortcuts edited through the Keyboard Shortcuts dialog. The Keyboard Shortcuts dialog is opened using the Accudraw short cut key '?' or via File > Settings > Keyboard Shortcuts.
Changes made to the AccuDraw / Keyboard shortcuts are typically stored in the file :
C:\Users\user_name\AppData\Local\Bentley\MicroStation\10.0.0\prefs\Personal.KeyboardShortcuts.xml
Thus these personal modifications do not affect other users.
To find the location and name of this file check the Variable MS_KEYBOARDSHORTCUTS by openning the Configuration Dialog ( File > Settings > Configuration > Configuration Variables ) and in the Search area keyin that variable name MS_KEYBOARDSHORTCUTS, select the variable in the list and the path and file name will be displayed in the Expansion are of the Configuration Dialog.
Complete List of AccuDraw Shortcut Key-Ins
| Original Author: | Carl Myhill |
