| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 02 November 2012 |
| Date modified | 02 November 2012 |
This document describes an example that has been used to verify the elastic deformation capabilities according to Hooke's law of PLAXIS. The problem involves axial loading under biaxial test conditions.
Used version:
