| | Product(s): | MicroStation | |
| | Version(s): | CONNECT Update 7 and higher | |
| | Environment: | N\A | |
| | Area: | Coordinate Systems | |
| | Subarea: | Geographic | |
You can set the Background Maps from the View Attributes dialog in the Background Map section.
The simplified method allows Street Map, Aerial, or Hybrid imagery.
2. Good internet connection
3. User must be signed into the CONNECTION Client. Note that a Bing Maps Key is not required for this functionality.
1. Open a design file
3. From the View Attributes dialog, change Background Map Type from None to Street Map, Aerial Imagery, or Hybrid Imagery. The Transparency of the Background Map can be changed as well. Some versions of CONNECT also contained an Elevation Offset setting.
See Video
MicroStation Blog: Microsoft Bing Maps
Enable Bing Maps to Attach as Raster
Other Languages Sources
Español
Deutsch
| | Original Author: | Maria Garcia | |
