| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 07 November 2012 |
| Date modified | 07 November 2012 |
This document describes an example that has been used to verify the elasto-plastic deformation capabilities according to the Hardening Soil model of PLAXIS. The problem involves axial loading under triaxial test conditions.
Used version:
