| Application | PLAXIS 2D |
| Version | PLAXIS 2D AE |
| Date created | 23 July 2014 |
| Date modified | 23 July 2014 |
When using the free field and/or compliant base boundary condition we need to create so-called node pairs along the boundary of the model (for this we manually need to create an interface along the boundary). Between the two nodes of a node pair a viscous damper is created which allows for the transfer of the input and/or free-field motion but also allows for absorbing the incoming waves.
Currently, however we can by default only see one side of this node pair in the Output program: this is the side of the viscous damper that also moves due to absorption of incoming waves. So, in general, the motion of this node is not equal to the input motion.
To be able to see and to explicitly check our input motion we should make the other node of the node pair visible in Output. To do so we can make use of a trick with a "dummy plate". See the steps below on how to apply such a “dummy plate”:
Note: the dummy plate should not be activated during the calculation.
Also, see attached graphs
Figure 1. Node selection for input signal on dummy plate
Figure 2. Accellerogram for soil node (B; red) and dummy plate node (A; blue)
