| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 16 November 2012 |
| Date modified | 16 November 2012 |
In an axisymmetric analysis, plates may be used as circular plates. This document describes an example that has been used to verify the bending of the axisymmetric plates in PLAXIS 2D.
Used version:
